08-03-2019 16:39
08-03-2019 16:39
My fitibit syncs no problem to my android phone (s9). But when I go to play music, it says ""connect phone pair your phone in settings app under bluetooth". Well it is paired, its syncing and it says paired in my phone. I am only having this issue when trying to use the music controls. Everything else works fine.
08-03-2019 16:40
08-03-2019 16:40
Also, Ive tried disconnecting and then pairing again, multiple times. Phone and versa are updated, and I have reset my phone a couple times as well.
08-03-2019 18:16
08-03-2019 18:16
On you Versa, when you go to Settings/Bluetooth, make sure that Music Via Bluetooth is On.
Maybe pair from there.
08-03-2019 22:43
08-03-2019 22:43
Your versa syncs through the Bluetooth lite. Music connects to the Versa Classic. These are independent channels. So yes the tracker will sync without BT classic connected.
Let's open the phones BT and on the Versa set the BT to visible. Now through the phone tap, confirm on the Versa then the phone.
Start a music or video app on the phone, then hold in the left button to bring up music control. You may have to change the controls to the phone rather than internal music.
08-05-2019 17:49
08-05-2019 17:49
08-05-2019 17:50
08-05-2019 17:50
