Telegram notification not showing on Versa
ANSWERED
My Versa doesn't get notifications from Telegram  although In the setting it shows that Telegram HD notification is on.
1 BEST ANSWER
Accepted Solutions
@Marjan572011 Welcome! It's nice to have you on board! Sorry to hear that you aren't getting Telegram notifications on your Versa. Which phone are you using? Is it compatible? If you are using an Android phone make sure the Fitbit app has the necessary permissions (settings, apps, Fitbit, permissions). Also check your privacy settings to show messages. Regardless of the phone you can also refresh the link between them by deleting all devices listed in the bluetooth settings area, restart your phone and restart your Versa by doing the following:
1.- Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
2.- Let go of the buttons.
3.- If your Fitbit watch doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
Let me know how it goes!
Alvaro | Community Moderator
1 REPLY 1
