06-04-2019 14:04
06-04-2019 14:04
I no longer am receiving texts on my versa and incoming phone calls are not showing up on my versa. I have synced it multiple times, removed the device from my phone and re-synced it several times as well. Any other ideas? Also confirmed under settings that my notifications are set to “on”.
06-04-2019 14:22
06-04-2019 14:22
@Branhama wrote:I no longer am receiving texts on my versa and incoming phone calls are not showing up on my versa. I have synced it multiple times, removed the device from my phone and re-synced it several times as well. Any other ideas? Also confirmed under settings that my notifications are set to “on”.
Not sure if you did this, but try holding in left button a few seconds. Check Notifications are not off there (might have to scroll left or right to see it.
Best Answer06-04-2019 14:19
06-04-2019 14:19
I have been having the same issue with mine since yesterday. I did have a few emails come through but my Versa did not vibrate when they came through. I only saw them because I checked my notifications. It is really frustrating.
I have reset both my Versa and my phone. I have deleted the app and reinstalled it. I removed the data and cache from the apps memory. I turned off my bluetooth and paired my phone and Versa. Nothing is working.
06-04-2019 14:22
06-04-2019 14:22
Best Answer06-04-2019 15:29
06-04-2019 15:29
I'm having same issue. I've trouble shooted every way you have. Following post
06-04-2019 15:43
06-04-2019 15:43
That fixed it!! I didn’t realize I could control notifications by holding down the left button. Also don’t know how all notifications were turned “off” there when they were showing “on” under my settings. Whatever though, it worked! I am now getting calls and texts via my versa. Thank you!
Best Answer06-04-2019 16:03
06-04-2019 16:03
I look at the left button as kind of a temporary quick-access 'do not disturb'.
Best Answer06-04-2019 16:53
06-04-2019 16:53
I am having the same issues and have tried everything as well. Following**
Best Answer08-19-2019 05:57
08-19-2019 05:57
My notifications are turned on. I checked on the Versa as well. It's not working. My Versa has never alerted me to notifications sent through fitbit either. Hmph.
