09-03-2018
21:13
13:22
HeydyF
09-03-2018
21:13
13:22
HeydyF
Text msgs do not open when tapping open. They disappear. Every other notification works perfectly. Even changed msg app. Nope! Samsung 8 Note.
01-01-2020 12:49
01-01-2020 12:49
@PrincetonFarm is it that your message body isn't being sent to the tracker, or that your not able to read the body of the message on the phone.
01-02-2020 07:39 - last edited on 08-19-2020 19:43 by LiliyaFitbit
It shows up on the the tracker that I have a message, When I hit open it
does not open on tracker, it just disappears. It does open on my phone.
Disappointing as that is the reason I purchased the Versa 2 to replace my
Alta
01-02-2020 08:27
01-02-2020 08:27
That is correct @PrincetonFarm as explained above, taping open will open the message on the phone.
To open on the tracker, if this app message can, the user simply wants to tap once.
01-02-2020 08:55
01-02-2020 08:55
01-05-2020 09:39
01-05-2020 09:39
I had to enable preview messages on my S10 Plus
01-06-2020 15:08
01-06-2020 15:08
When I hit open on the watch the message disappears.
01-06-2020 17:37
01-06-2020 17:37
I had to change my privacy settings on my phone. I had it set to do not show message and that made it so I couldn't open and reply know my versa!
01-07-2020 01:57
01-07-2020 01:57
@Czarina0525 I believe that is correct. Pressing open will open the message on the phone and remove it form the tracker.
01-07-2020 03:49
01-07-2020 03:49
01-07-2020 09:12
01-07-2020 09:12
Yes, pressing open on the tracker will open the message on the phone, not on the tracker.
To open press the message once.
01-08-2020 12:47
01-08-2020 12:47
01-13-2020 11:57
01-13-2020 11:57
I'm having the same problem, I have a Galaxy 7 and it will show I have a message with the options "Mark as Read" "Reply" "Open" and "Clear". If I touch "Open" it will open up the message on my phone but disappear from my watch. If I tap on "Message" nothing happens. I've tried changing my lock screen, permissions on my app, phone, everything....
01-13-2020 12:38
01-13-2020 12:38
@Czarina0525 and @fustrated2020 as muted above, pressing open on your wrist is suppose to open the message on the phone not on the wrist.
To read the message on the wrist, the user needs to tap the message once. This will, depending on the app on the phone that sent the message or the settings, open the message on the wrist. It will also give the option to open on phone, clear, mark as read, reply, cheer, etc seeing on the app sending the notification.
01-13-2020 13:41
01-13-2020 13:41
01-13-2020 13:47
01-13-2020 13:47
That will depend on the messaging app, not Fitbit, or what settings have been chosen in the phone.
For me text messages open with default Samsung message.. YouTube gives me the heading if the video. Facebook shows me the basis of what Facebook sent to email.
01-13-2020 13:55
01-13-2020 13:55
01-13-2020 15:05
01-13-2020 15:05
No it does not, as I stated in my original message if I tap on "message" which is all that comes across on the top of the screen on my wrist nothing happens. I reads "Message - 1 new message" if I tap on that nothing happens, if I scroll down I see the other options "Mark as Read" "Reply" "Open" and "Clear"
01-14-2020 10:58
01-14-2020 10:58
I finally figured it out. You need to go to settings in your "Message +"! Not the settings for the phone. Click on the Message + icon to bring up your text messages and click on the menu bar at the top next to "Conversations" scroll down to "Setting" then to "Notifications" Look for "Privacy Settings - Show a preview of received message on the Status Bar and Lock Screen" and turn on. this is for a Galaxy 7. Whew!
01-19-2020 10:57
01-19-2020 10:57
Thank you
02-17-2020 21:36
02-17-2020 21:36
Nope. Click on open, messages disappear
