The GPS on my Versa Lite is working intermittently
Fed up! GPS frequently fails to work. Cycled over an hour. Registered fat burn etc. But no map no mileage recorded again. Most days no issues but lately fails to locate. App says I’m up to date snd synced. I’ve disconnected and reconnected but still have issues.
2 REPLIES 2
Hi there, @Wantobfit. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out. I understand how you must be feeling.
For troubleshooting steps, see Why isn't GPS working on my Fitbit device?
Moreover, please be advised that environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked—either because you're indoors, underground, or due to another reason—GPS won't work.
Note: If the GPS signal is lost during the exercise, a map might not appear in the Fitbit app. For more information, see: How do I use GPS on my Fitbit device?
By the way, I've moved your post to the Other Versa Smartwatches board for organization purposes.
Thanks for reply. There is no reason for the GPS signal to fail in an area which on a daily basis works for everyone using harming etc. Fitbit appears to have a glitch
Sent from my iPhone
