The Yoga icon on my Versa 2 shows as Running
Every time I log a yoga exercise session, Fitbit shows the running icon instead of the yoga icon, seems like it may be a bug? Does this happen to anyone?
10 REPLIES 10
Hi there @pinkmooncita, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2.
May I know if you're getting the little guy running icon on the watch itself or on the Fitbit app/fibit.com dashboard? I tried starting a yoga exercise on my watch and I get the little guy doing yoga, the same applies for my Fitbit app when I try manually logging the activity. You can attach a photo/screenshot of what you're getting so I can go from there.
  • When you're in the reply page, click on the Insert Photos icon (the little camera).
  • Then, click on the Choose File in the middle of the grey window that will pop up.
  • Search for the photo on your computer or phone and click on Open.
  • Once the image shows up in the grey windows, select the size and the position and click on Done.
In the meantime, I'd suggest restarting your watch and try again to start a Yoga workout to see how the icon appears this time.
Catch you later!
I had the same problem on my versa 2 and now versa 3. If I manually log it I'll get a yoga icon, if it's excercise from my versa it's a running icon
Did you manage to solve it in the end? I still get the running icon even now 😑
No, Yoga and pilates still show as running icons. It's so frustrating! I've tried everything 😡Sent from my Galaxy
Same thing, I start a yoga session on my Versa 2, and it shows up as a run in the Fitbit app. This issue doesn't appear to be solved.
Hello,
I'm having the same issue. If I start the exercise on my Versa 2, I see the yoga guy, and if I start the exercise in the app, I also see the yoga guy. However, if I start yoga on the Versa and sync it with the Fitbit app, I get the little running guy.
Screenshot
I have the same issue on my Sense as well. So far no solution. Basic checks like restarting the watch, the app, etc. have no effect.
Hi @MarreFitbit
I am having the same yoga icon issue as @pinkmooncita and the others replying to her post. Resetting my Versa 2 does not fix it. This issue definitely does not appear to be fixed. Any other suggestions? Thanks 🤞🤞
