02-01-2020 10:41
02-01-2020 10:41
How can I find how much kilometers I did in one excercise, i.e. biking or runnig a distance?
Best Answer02-02-2020 07:25
02-02-2020 07:25
OK I think your asking why your exercises show no distance.
Are you letting Fitbit auto detect exercises? If so then this is the reason for no distance.
If a user wants to see distance for an exercise, like a walk, the user will need to use the multisport mode called Walk that is found on the tracker. This requires the user to manualy start and stop the recording of the walk.
Best Answer02-01-2020 10:37
02-01-2020 10:37
(How) can I see on the watch itself what exercise I did, like walking/runnig/biking?
Best Answer02-01-2020 12:14
02-01-2020 12:14
by going to your exercise log through the Fitbit app or on the web. On the app, tap the exercise tile normally it will say X of 5 days.
Best Answer02-01-2020 12:16
02-01-2020 12:16
If course @Riavanderkolk swipe up until you see the Exercise Tile. Now swipe left.
Most of these tiles will swipe.
Best Answer02-02-2020 06:20
02-02-2020 06:20
Thanks Rich, but still I can't find distance per exercise. The web says N/A there, while it does give a total distance over the day. Do I need to change something in the settings, or what??
The phone gives calories, heartrate, steps etc. but also distances only over the whole day...
Best Answer02-02-2020 06:33
02-02-2020 06:33
When I swipe left (on the watch)I see number of steps and calories burned, but not the type of exercise and only about the whole day, not per exercise
Best Answer02-02-2020 07:19
02-02-2020 07:19
@Riavanderkolk your swiping the wrong tile. You want to swipe the exercise tile. On my Versa it is the last tile and labeled Weekly Exercise.
02-02-2020 07:25
Best Answer02-02-2020 07:29
02-02-2020 07:29
Best Answer02-02-2020 07:36
02-02-2020 07:36
Best Answer02-02-2020 07:44 - edited 02-02-2020 07:50
Did you use the manual start and stop of the exercise mode, or did you let Fitbit decide what you where doing? Auto-detected exercises will not show distance.
I just realized that, to confuse yourself and others, you had to independent but same question. I've merged them.
