12-28-2021
12:12
12:46
12-28-2021
12:12
12:46
Battery is stuck on 49% on the dashboard but different on the actual watch
12-28-2021 12:47 - edited 04-20-2024 09:20
Hi there, @25asil. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Regarding the battery level on the Fitbit app, note that it updates every time you sync. That means that if your watch hasn't synced yet, your app will still show the battery percentage of the last sync.
Once you charge your watch make sure to sync and you'll see that the percentage on your Versa 2 will match with the one on your Fitbit app.
If you're running into syncing difficulties, see Why won't my Fitbit device sync?
Best Answer12-28-2021 13:17
12-28-2021 13:17
This has happened to me as well. Customer support as usual is sticking their heads in the sand and refusing to recognize the issue.
I was able to update the power level display on the app by closing it and reopening. It forces a sync that will actually update the power level display. I suspect this issue will hang around until the next app/watch update.
12-28-2021 13:19
12-28-2021 13:19
This is wrong. The watch will sync to the app in every respect but the power level. In order to update the power level one has to close the app and reopen it.
12-28-2021 14:21 - edited 12-28-2021 14:22
Thanks for this help Allan, I’ve been battling with this problem for ages with my Charge 3. I’ve searched high and low for help to no avail - until today! Worked like a dream - you are a star!
