04-19-2018 15:08 - last edited on 07-13-2022 08:21 by AndreaFitbit
I've been having alot of issues with my Versa. One of which is battery life of only 27 hours. I was told to charge phone and record syncs, still charge lasted only 27 hours. NOW Support says to charge for at least 2 hours even if watch reads 100%. Hopefully this info is helpful to someone.
Moderator edit: updated subject for clarity and format.
02-20-2020 10:03
02-20-2020 10:03
So, basically turn every feature of the watch that makes it worth using off? That would work though.
Mind used to last 4 days with those settings on Pace- allowing me to use the watch with the features turned on. A year later, I have to charge every two days. Maybe it's time for a change...
02-20-2020 10:11
02-20-2020 10:11
02-20-2020 12:37
02-20-2020 12:37
03-14-2020 06:07
03-14-2020 06:07
Thank you for the information! However much of what you’ve shared are features that the Versa has that we like. Had I known that Fitbit could not keep up with “reminders to move, or notifications etc,” I would have gotten an Apple Watch and called it a day. I should not have to compromise just for battery life! Fitbit needs to address this issue! Does Fitbit have any plans on addressing the issue?
03-14-2020 06:30
03-14-2020 06:30
I have done all of those things. I basically have a watch and I still have to charge it every other day. My Versa 2 is about 3 months old. Completely disappointed!
05-13-2020 00:47 - edited 05-13-2020 00:48
For what it's worth, I find many of the tips from Support to be red herrings, as usual.
I'll avoid speculation as to how the thing actually works but, having had 3 of these devices, I know how they should work......and you DON'T need to turn off all the features.
My Versa 2 went from a 5+ days battery life to just over a day within a short time. I was using a quite high-powered charger so I factory reset the watch and started plugging the charging cradle into a laptop port & the watch is now as good as new.
No idea whether the factory reset was necessary or not but, at least I can confirm that using a fast charger for several months did NOT 'fry' my battery - it definitely appears to be software rather than hardware (in my case).
05-30-2020 16:16
05-30-2020 16:16
Probably 80-90% of your suggestions were the very reasons I bought the Fitbit Versa and yes I am someone who can't get 48 hours out of my battery without a warning. Why make something if you can't use it? Thanks, Linda
05-31-2020 08:23
05-31-2020 08:23
05-31-2020 12:18
05-31-2020 12:18
Today my battery went from 100% at 8:30am to 18% at 2:15pm. Same thing yesterday. I did not notice this problem before the recent update, and have not altered any settings to make my battery last less. What is going on?
06-08-2020 14:57
06-08-2020 14:57
My verse only last about two hours. I have the all day sync turned off and the GPs turned off
I disagree with the comments above, we should be able to use the functions of our watch and it lasts longer than four hours or less. I’ve only started having this issue with the last update to the software.
06-09-2020 03:42
06-09-2020 03:42
Basically turn off everything that your fitbit is built to do just so you can have other people see your wrist and thinn you have a cool gadget on
06-15-2020 17:05
06-15-2020 17:05
I got my versa2 early June. It's never made it to the advertised 6 days, or even 4 days. I had always on display turned off, disabled quick view (so I have to hit the button for the clockface to show up).
I'm lost on what to do and want to return it since the battery life is disappointing, I get 2 days at best.
06-29-2020 09:27
06-29-2020 09:27
I bought my Versa 2 back in January (ish) and it never held a charge longer than 3 days (no matter how many setting I turned off or how long I charged it). Since Corona lock down in late March, I haven't been wearing it. I just charged it and put it on at approximately 4pm on Friday and it was completely dead by 4pm on Sunday. I Don't listen to music or have any alerts or alarms. It isn't showing me weather or my heart rate..Actually, if only tells me the time when I ask for it !!!! it the worst watch I've ever owned and I didn't even know I was buying "just a watch". I feel scammed. If the battery cannot accommodate any of the features...then it shouldn't have the features! I'd love to return it but fear its been too long since I purchased it.
08-24-2020 19:22
08-24-2020 19:22
I have done all of the things suggested here and the battery still lasts just one day (if I am lucky). I got the versa for the features it offers and thought I would be able to use it at least one full day. It doesn't make sense that you should have to turn everything off just to have a full day of battery! I have grown weary of fitbit. . . .
08-24-2020 19:23
08-24-2020 19:23
Mine does the same. Sorry you aren't able to make use of your versa.
08-25-2020 02:54
08-25-2020 02:54
09-08-2020 18:48
09-08-2020 18:48
I thought you had to take if off charge as soon as it reached 100%. I've read that you don't charge over night for this reason.
09-08-2020 18:53
09-08-2020 18:53
I was thinking the exact same thing. All these fantastic options available but because of the poor battery life you can't use any of them. 😕
09-08-2020 19:33
09-08-2020 19:33
09-09-2020 05:23
09-09-2020 05:23
I can't see all day sync. I have a versa. My battery was fine a couple of months back and now I'm charging every day. Could it be an update that is draining the battery?
