10-01-2018
18:47
09:12
HeydyF
10-01-2018
18:47
09:12
HeydyF
Thanks for the information. It was useful. But now I'm facing another
problem with my batteries. They don't even last for 2.5 days. I applied all
the solutions mentioned in the previous email and website but it was not
working kindly help me out in that.
10-05-2018 09:19
10-05-2018 09:19
Hey @PARTH90SHAHVERS, it is great to see you around! I appreciate you have tried some tips to make the battery of your Versa last longer. Let me ask you this, when you charge your watch, do you wait until is fully charged? I mean a 100%? What are you using to charge it, a wall adapter or your computer?
I'll be around!
10-05-2018 09:51
10-05-2018 09:51
I'm having the same problem. I've charged it with everything from a charger that plugs into the wall, to a computer. Still, I'm lucky if I get 28 hours.
10-05-2018 21:53
10-05-2018 21:53
10-09-2018 19:39
10-09-2018 19:39
As I mentioned earlier. I start charging when it's 10-12% and charge till 100% with frequent monitoring as it don't gets overcharged. As soon as it gets 100% I disconnect the charger with my LAPTOP. I request you to provide me a concrete solution because it's draining rapidly even i don't connect with GPS neither use ruff.
Thanks
Namaste
10-12-2018 13:05
10-12-2018 13:05
Hey guys! @PARTH90SHAHVERS, @mr_jtee, I hope you are doin' fine!
Since the issue with the battery of your Versa continues to happen, since it still draining, I suggest you to get in touch directly with our Support team so they can further assist you.
Have a nice day1
