08-14-2021
18:03
11:46
08-14-2021
18:03
11:46
Battery draining in less than a day . with 100 % I'm not able to get one single day battery . Before i use to get 4 days battery no not even a single day . Fed up of charge twice a day 💔😔
08-15-2021
11:14
11:02
08-15-2021
11:14
11:02
This is a recent known issue.
In certain cases it may be improved by doing a sync, then turning off the Bluetooth on the phone, doing a Shutdown of the watch and after 10 seconds place it on the charger to restart it and fully charge to see if it improves..
If this cures the problem you will at least know its the App causing the problem.
If not probably best to contact Fitbit Support directly. They may be able to help you.
