The battery on my Versa is draining very quickly
ANSWERED
recently my battery is dying very quickly so i have to restart it to stop it from dying in 2 days why is this happening
1 BEST ANSWER
Accepted Solutions
Hi there, @smile786. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
As you may know, your Versa battery should last up to 4 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or animated clock faces. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
1 REPLY 1
Hope that helps.
