07-11-2021
		00:10
		09:13
		07-11-2021
		00:10
		09:13
I noticed a dark spot on my screen. I thought it was dirty but turns out the screen is "bleeding" inside. My question is will it spread or just stay the same size?
From day 1 I've kept a plastic cover on it so I really don't know what happened to it
 Best Answer07-12-2021 09:23 - edited 03-20-2024 10:46
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @Crowder. Thanks for stopping by in the Community Forums and for the details provided in your post. I understand where your concern is coming from.
To better assist you, would you mind sending a photo of the dark spot referring to? In order to add a photo to your reply please:
In the meantime, please restart the Versa Lite as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
Hope that helps.
