The weather app on Versa 3 is stuck on Celsius
ANSWERED
Weather on watch shows Celsius. I went to units and made sure Fahrenheit was selected. Then restarted the app and my watch and resynced them both. But still showing Celsius.. any thoughts??
61 REPLIES 61
Glad I could help! It took a lot of digging to find the solution, but
hopefully FitBit will provide a fix for this snag.--
Phil Muthersbaugh, D.Min. College Place, WA
Thank you so much!!
I got it handled- but get the TRX option in there again :)) Thanks.
Sent from my iPhone
There are actually 2 places that need to be set to Fahrenheit. Click on photo, versa 3, gallery, scroll down to weather app, click settings and change to Fahrenheit. I struggled for a month before finally getting support to get me there .
You are a life saver! I just got a versa today and have been going crazy all afternoon. Your explanation is very concise and easy for this boomer to understand.
Glad I could help. It took me awhile to find a solution so figured others
might benefit from it. Glad it worked! --
OMG thank you!!! This has been driving me crazy.
You are most welcome.--
Omg thank you! This is the answer.
Mine is doing the same thing.  I deleted the versa 3 and went through setup.  It is still showing Celsius.  It was correct until recently.  Could this be a problem with an update?
My new Versa 3 reverted back to Celsius after about a month. I reluctantly
contacted Fitbit via chat and they sent me the steps to change C to F. It
was a pain, but it worked. My Versa 3 is still tracking temp on F. Hope
this helps you!--
Hi @janlanac - if you remove the watch Weather will revert to default.
It is best fixed by How to change Temperature - for Weather, Centigrade - Fahrenheit, Versa 3
Ok, I found where it was set to Celsius and changed it. I pulled down to sync and then checked weather. It still shows Celsius.
Sent from my iPad
That’s exactly what I did—same result. Do I contacted Fitbit via “chat” and
the walked me through it. Make sense--
This worked thank you SO much!!!
This actually worked.
just bought mine about 4 days ago , im having all these same issues , can't get weather right can't hook to Pandora WTH I can't even get it to stay on I have to keep clicking the side to get random stuff pop up 🤔
loriphillips0093@gmail.com
Hi @Twoez2find - there is quite a lot to learn with the new watches.
See my earlier post in this topic for the weather setting, there may be 3 different places.
You can swipe the watch face to the right to get to Quick Settings and choose the options that you want there.
AHHHHHH THANK YOU.
You’re welcome!--
