07-12-2018
18:33
08:23
AlejandraFitbit
07-12-2018
18:33
08:23
AlejandraFitbit
I have had the Fitbit One for a long time. It still works great. I even washed it one time accidentally & it still works. I was wanting to update my Fitbit & was thinking of buying the Versa. After reading about all of the problems here, I think I’ll wait until the problems are worked out. That’s a lot of money for something that doesn’t work like it should. Too bad!
07-13-2018 08:25
07-13-2018 08:25
A warm welcome to the Community @elkayr.
If you have a compatible mobile device, keep the app updated and use the watch properly, it shouldn't give you any problem. If you decide to make the purchase, here you will find the Versa manual for any inquiry you might have.
Let me know if you need anything else. ![]()
Best Answer07-13-2018 10:41
07-13-2018 10:41
I've had 2x Ones and 2x Blaze and was keen to have a Versa. After much research I bought the Samsung Gear Sport and am a convert after many years using Fitbit. Shame really.
Best Answer07-13-2018 10:50
07-13-2018 10:50
I'm trying my second Versa. Returned the first one. If not better luck this time, I too will be switching to the Samsung!
