03-05-2019 21:38
03-05-2019 21:38
Versa is showing time 3 hours behind my correct time. Rest a few times. Shutdown a few times. Changed clocks a few times nothing seems to work. Frustrated! I need help!
Best Answer03-06-2019 00:32
03-06-2019 00:32
You can't manually set the time but it should reset itself whenever it syncs to your phone or computer.
If it seems to be syncing ok but it's still out then check that your timezone is set correctly in your profile at https://www.fitbit.com/settings/profile
If you do update your timezone you will need to sync to copy the change across to your fitbit.
03-06-2019 00:32
Best Answer03-06-2019 06:57
03-06-2019 06:57
Thank you so much it worked! Don't know how it got changed.
