12-24-2018 19:26
12-24-2018 19:26
My steps now appear above the battery percentage and the date. How do I fix this? I have tried restetting the Versa twice, moving the tiles and getting rid of the tiles in "settings".
Best Answer12-25-2018 01:15
12-25-2018 01:15
This might be a SOFTWARE bug in OS as you know that FITBIT OS 3.0 is recent update as well as is not so stable currently. So I suggest you to stay tuned/updated from here. Hope that it will help you..
Best Answer12-25-2018 06:46 - edited 12-25-2018 06:48
@ajcm40in the main OS3.0 thread there was someone who reported exactly the same issue. It is definitively not a general bug as few users seem affected, for most ppl the Today app works just normal and fine. Maybe it is a strange interaction between say OS3.0, Today app and a ("buggy") clockface, there are many of them.
Not sure what the resolution was for the other guy, but as resetting the watch doesn't help and neither you can uninstall/reinstall the today-app there is really only one thing left to do... the dreaded factory reset 😞
12-25-2018 06:51 - edited 12-25-2018 06:54
Hi, or, before doing the dreaded factory reset, install another clock face and see if that solves the problem. I would suggest to change it to "Minimal Analog" clock face.
Best Answer12-25-2018 06:54
12-25-2018 06:54
I did two factory resets, five soft resets, and a bunch of soft resets of my iPhone. It seems to finally have worked, but not only was the today view changed, my Versa stopped connecting to Bluetooth. It was a nightmare.
