01-28-2024 08:27
01-28-2024 08:27
01-28-2024 09:15
01-28-2024 09:15
One possibility: If you were with Fitbit before Google takeover and have switched to Google account, it seems Google has just switched to taking your age from your Google account instead of from what you had set it in Fitbit. Many people had just set a random age in Google to get an email account, or somehow it has defaulted to 1/1/1900, and that has totally messed up the heart rate zones, for many, getting them in zone nearly all day. Check your birth date in your Google account. Alternately, in Fitbit phone app from Today screen, tap 'You' at bottom right, then your name with join date will show your birthday.
Let me know if that was it.
01-28-2024 09:18
01-28-2024 09:18
@SaraOdessa Did you recently migrate to a Google account? There is an issue where users migrated to a Google account, but their Google account has the wrong birth date. Fitbit seems to be using the Google account birth date. If you didn't migrate recently, I don't have any good idea. What are your heart rate zones when you tap on your zone minute icon or tile? Do your moderate, vigorous, and peak zones make sense for someone your age?
Laurie | Maryland
01-28-2024 09:25
01-28-2024 09:25
01-28-2024 09:30
01-28-2024 09:30
It doesn't matter when you changed to the google account. Google (without warning or announcing it) just switched which source they took your birthdate from.
01-29-2024 01:29
01-29-2024 01:29
Unfortunately the problem is still there after changing my birth date. Do you have any other suggestions on what might cause the problem?
01-29-2024 08:16
01-29-2024 08:16
Then you will just have to analyze it your self. If you are familiar with your usual heart rate when exercising, look at your heart rate zone limits to see if they seem reasonable exercise targets. Then look at the times when you are earning AZM to see if you are getting reasonable heart rate readings. Either your heart rate readings are off, or your heart rate zones are off. Once you figure out which is the source of your problem, then can investigate further. If the zone limit seem crazy, write them down and post here.
