02-28-2019 12:05
02-28-2019 12:05
I just upgraded from a Blaze to a Versa. The Versa is significantly over counting floors. For example on a day where I did 5 floors at most, I received credit for 171! On another day it gave me 88 floors where there is no way I did more than 10. Most days it is only inflating by 10-20 floors. Also the times when it says I am getting all those floors are times when I am walking in flat areas, so it wasn't inflating actual floors.
I've seen some other posts about this and frankly I'm not buying the barometric pressure change as an explanation as I don't think I've been somewhere the pressure changes that dramatically or frequently. I live in the same place and have the same habits I did when I had the Blaze 2 weeks ago and it never over counted that much.
If the altimeter is the little hole on the back side of the Versa in the lower left corner then it is clear and dry. I've also tried restarting. And the setting is on dominant arm since I wear it on that arm.
Any other ideas?
Thanks!
Best Answer02-28-2019 12:26
02-28-2019 12:26
I was a blaze user as well until recently... I've noticed that if it's really windy, my versa counts a lot of floors. Not sure if this is the reason for your excess.
