01-25-2023 19:38
01-25-2023 19:38
I went on a 3 mile walk with my dogs today. This is the first time I have done this. When I have gone on walks before I track the activity. I did the same today and for some reason it's not showing up. But the steps I took are. Has this happen to anyone else. And how can you retrieve the activity?
01-27-2023 05:50
01-27-2023 05:50
Open your Fitbit app and check your privacy settings. Go to social and sharing, and allow average daily step count to be seen by your friends. Mine was locked, which must have happened with the last update.
01-27-2023
00:27
16:37
01-27-2023
00:27
16:37
Hi @AishaViera - it should still show up in exercise as an activity once you have synced the watch fully. But if the watch had stopped syncing there is not way to track the walk on the phone, using it's GPS.
To start a clean situation logout of the Fitbit App and restart both watch and phone. see also
How do I restart my Fitbit device?
Why won't my Fitbit device sync?
01-27-2023 05:12
01-27-2023 05:12
I’m getting the same thing. It’s showing my steps, miles, etc… But when I click on the “friends“ tab, it shows me as having no recent activity.
01-27-2023 05:19
01-27-2023 05:48
01-27-2023 05:48
Thank you, but I’ve already done all of that. And I spent 30 minutes on the phone with Fitbit Support this morning. Luckily, I just figured it out myself.
01-27-2023 05:50
01-27-2023 05:50
01-27-2023
13:29
16:37
01-27-2023
13:29
16:37
@scapr68 Thank you for sharing your solution. I marked it so that others can find it easier.
Glad to read that you figured it out.
04-15-2023 16:41
04-15-2023 16:41
I have had the same problem since Sunday, no tracking of my activity but steps are in there. I have called the help desk, have actually changed fitbits because they said, mine was no longer functioning and when I read this, I thought, okay this might be the problem. They had me factory reset (I thought everything would be gone but it was not from the day). I checked and my social and sharing is not blocked. Any other ideas? The help desk, I'm sorry are more interested in getting great surveys. I even got one here before I finished this post. Very disappointed in their help. the community has helped me before so now I am turning to you again. Jo-Ann
04-15-2023 16:49
04-15-2023 16:49
It didn't work for me.
04-15-2023 16:58
04-15-2023 16:58
Tried all the above....so frustrating.
04-15-2023
18:32
16:31
04-15-2023
18:32
16:31
Hi
@Joneill119 - in your case you may have a problem in the app. You can check this on your Versa 2.
On your watch swipe up to get to your Today view and see if the information is there, it should be after a factory reset but if not scroll to the bottom and change the setup.
In the Fitbit App, logout and login and click Edit with the green popup.
Remove the goal or tile that isn't working properly and add it again, or add it if it is missing and click Done.
Then sync the watch by a pull down on phone display.
04-15-2023 19:15
04-15-2023 19:15
04-15-2023
19:34
16:35
04-15-2023
19:34
16:35
@Joneill119 - did you restart the watch again?
Turn off all other Bluetooth devices if you use tablets as well as phone.
Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Login again and wait for any pair, link or Fixit prompts and sync with a pull down on the phone display.
04-15-2023 19:59
04-15-2023 19:59
