Tracking a bike ride with screen on
ANSWERED
Hi! I started to track my bike rides and I was very annoyed when I realized that the screen does not stay awake as when I am running. Is there some kind of setting I need to activate? It is very annoying and dangerous when I want to check the distance or the heart rate and have to tap on the watch screen.
1 BEST ANSWER
Accepted Solutions
Hi @DRodrigues If you go to the exercise app on your versa you will be able to find the "Bike" workout. On the bike workout you should be able to see a setting's button, if you select that and scroll down the bottom you can the "select screen stay on" mode. You can also customise the stats, like what you see first.
I hope this helps you.
Callum Slatyer
1 REPLY 1
Callum Slatyer
