09-04-2018
04:06
10:12
HeydyF
09-04-2018
04:06
10:12
HeydyF
Versa won't sync or track with Samsung Galaxy A3. Really dissapointed with this. Any ideas? Have a feeling should have stayed with my old Garmin!
Best Answer09-05-2018 10:11
09-05-2018 10:11
Hello @Frodite, let me give you a warm welcome to the Fitbit forums! Oh! 'm afraid that your phone isn't a compatible device, just like @ACG said, so that is why you are having inconveniences to connect it with your Versa. However, I always suggest the users to follow the troubleshooting in this help article: Why won't my Fitbit device sync? I can't guarantee that it'll work but you can give it a try. 😉
Remember that you can also try to sync your watch with a computer or if by any chance you have it, another compatible device.
Keep me posted!
Best Answer09-04-2018 20:06
09-04-2018 20:06
Hello @Frodite
Here are the Fitbit supported devices
https://www.fitbit.com/devices
Restart your phone and also try a reset on Pg.68:
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
09-05-2018 10:11
Keep me posted!
Best Answer09-13-2018 14:33
09-13-2018 14:33
Hi heydy. took your advice and restarted the Versa. Also turned off the power saving mode on the phone. Versa now tracks using phone GPS and also syncs. Used versa this afternoon and worked perfectly. Correct info shown on both Fitbit app and strava.
thanks for the help.
Best Answer09-14-2018 05:15
09-14-2018 05:15
Hey @Frodite! Thanks for the update! Sounds great that your Versa is syncing fine now and tracking your data. I appreciate you have taken the time to restart it as I previously suggested. I'm pretty sure that this tip will help other users with the same inconvenience, to solve it.
If you have further questions or comments, let me know!
