06-06-2019 04:47
06-06-2019 04:47
I have a versa and my boyfriend has a iconic
we can start at the same time and run the same but he will gain in distance and be ahead and we should be the same. Bc we are going the same distance. Anyone else have this problem? I have an Apple iPhone 8plus
06-06-2019 06:38
06-06-2019 06:38
Are you saying that his records the same run as a longer distance than yours?
Distance is determined totally differently depending on whether or not on is using GPS.
Were either or both of you using GPS?
06-06-2019 06:56
06-06-2019 06:56
I believe my GPS is on it’s like we will start together and his will already start out .4 more that me then it will be like .25 off he. My BF we run a mile his will clock a mile and me says 75 not a mile
06-06-2019 09:31
06-06-2019 09:31
You will see a little phone in the top left. If there is I gps signal there will be a line through the phone. Also if the gps was used there will be a map displayed. Does the map look correct?
Are both of you waiting for the tracker to have a good gps lock?
