07-29-2018 08:39
07-29-2018 08:39
I'm a big runner and have always used map my run. Recently I purchased the versa and my distance and time do not match up to the map my run app. It's off anywhere between a half mile to a mile and around 5-8 minutes in time. Anyone else havethis issue or have suggestions?
 Best Answer07-29-2018 10:38
                              07-29-2018 10:38
I'm not sure what is happening @Running2012
The time will be when the activity is manually started and stopped.
If the auto detected funtion was used, there would not be any distance recorded.
07-29-2018 11:04
07-29-2018 11:04
l your pain I use map my run too to log my runs as the versa is always out on the distance I ran 20.49km to and the versa only logged 17km!
 Best Answer07-30-2018 10:37
07-30-2018 10:37
Yes, unfortunately this is a huge problem that many runners and bikers are running into with the Versa. The GPS is constantly connecting and then is losing the connection every 30 seconds to 1 minute in which you're exercising. This has been an issue that's been occurring since the watch first came out in April.
Many of us have returned our Versas and switched over to other watches because unfortunately, there hasn't seemed to be a solid solution introduced from Fitbit yet.
 Best Answer07-30-2018 11:31
07-30-2018 11:31
thank you for your response I appreciate that which one did you end up getting when you return the Versa?
 Best Answer07-30-2018 11:33
07-30-2018 11:33
07-30-2018 17:36
                              07-30-2018 17:36
That is where the Ionic with it's built in gps is what I would choose.
09-03-2018 15:06
09-03-2018 15:06
I use map my run as well. Today I mapped out an 11 mile run and my versa was off by almost a whole mile!
09-03-2018 19:08
                              09-03-2018 19:08
How was the recorded map @SBrim, or you sure that having to apps accessing GPS hasn't caused any timing problems?
