02-23-2020 15:21
02-23-2020 15:21
Hi
Just upgraded to V2 hoping sleep tracking is better. My V1 tracked for a year and a bit, then became an intermittent tracking (every few nights). So hoping to improve on V2
Question: had music successfully transferred to my V1 before...how do I get them to V2? the app doesn't seem to let me store things??
02-23-2020 17:33
02-23-2020 17:33
I found a thread that says I need to download fitbit connect app....but that page is gone and google search didn't turn up anything??
Best Answer02-23-2020 21:18
02-23-2020 21:18
Hi @rphcc7 You need to download the music from your laptop or computer again. To find Fitbit Connect, go to your computers app store and search for Fitbit Connect. Here is the link to how to download music (plus other things)
Helen | Western Australia
Best Answer02-24-2020 15:07
02-24-2020 15:07
Hi. Using Windows based PC and in App store there is only on e Fitbit app which is the desktop app. Is that the same as the Fitbit Connect?
Best Answer02-24-2020 16:42
02-24-2020 16:42
No it isnt the same, though it looks very similar. Did you do a search for Connect? That is the only way I can find it. I uninstalled the app, searched for Fitbit Connect amd installed what came up from the search, though I really couldnt see the difference (no big name saying Fitbit Connect!), and it worked to transfer music.
Best Answer02-24-2020 17:41
02-24-2020 18:37
02-24-2020 18:37
thanks. the URL under the first answer's page leads to an error message ...
