Traveling internationally: wi-fi and time zone changes
I read in the Versa manual that certain wi-fi networks will not let the Versa connect to my iPhone Fitbit app, apparently because they require logins, etc. So, when I land in another country in a different time zone, how can i be sure that my Versa can connect to my iPhone and make the time zone change on the Versa?
2 REPLIES 2
If you use the wifi in your hotel room most will only require you to sign in once and will then remember the connection. You could also purchase a small amount of international data and only turn on the data to sync and then turn it off.
I travel to Europe every year and have never had a problem.
A normal sync will require the cell phone to have access to the internet. This should not be a problem with the rooms wifi.
