01-03-2021 18:52
01-03-2021 18:52
When I run outside and use GPS my step count is approximately 2000+ To equal a mile. When I select treadmill as exercise a run or walk of over 9000 steps comes in only at 2 miles. Why would it not use my usual step count to convert to miles?
01-04-2021 07:33
01-04-2021 07:33
Hi @SunsetRunner
Welcome to the forum. When walking/running outside with GPS turned on, your Fitbit isn't using your step count to calculate distance/miles. It is using the GPS data. On a treadmill, it is using only step data, which will be different. However, it shouldn't be 7K steps different. You may want to adjust you stride length by going to your Fitbit Dashboard and edit, settings. It's also worth noting that typically stride length is shorter on a treadmill, thus it will take a more steps to cover the same distance.
Best Answer01-04-2021 12:19
01-04-2021 12:19
@SunsetRunner -
I actually typed everything below five hours ago, the Fitbit server was pitching a fit at the time.
GPS assisted walks do not take steps into consideration and therefore do not take your stride length, which appears to be approximately 30 inches, into consideration.
Since the treadmill exercise does not use GPS, for obvious reasons, it calculates distance using the formula steps * stride_length. From what you have stated, it sounds like your stride length is set to about 14 inches.
To verify your stride length:
I have a fixed stride length of 30 inches and my treadmill sessions distances are consistent with that 30 inch step. I just verified two weeks worth of two-a-days on the treadmill and they all range between 29.6 and 30.1 which is understandable with miles being rounded to two decimal places and steps not being rounded at all.
My virtually null difference isn't anything like your huge difference you are reporting.
Good luck and welcome to the boards.
Best Answer01-08-2021 13:15
01-08-2021 13:15
Thanks so much for taking the time to explain and help me fix this. Greatly appreciated!!
enjoy the weekend!
m
Best Answer01-08-2021 13:17
01-08-2021 13:17
Thank you Marci! Appreciate your help for fixing this!
Enjoy the weekend !
m
