09-10-2019 10:24
09-10-2019 10:24
I have this problem always when i'm in the shower but didn't bother that much.
Lately I started swimming a few times per week, and now it does bother me.
Because of the contact with water, my Versa watch turns on all the time. The water works like a finger, and will tap random things. Sometimes it stops my exercise, etc...
Now how can I disbale/turn off the double tapp action ? Please !
09-10-2019 11:07
09-10-2019 11:07
Hi, long press the left button untill the activity screen pops up and set "Screen activation" to manual instead of automatic. This should solve your problem. Regards kuzibri
Best Answer09-10-2019 11:35
09-10-2019 11:35
I see, thanks for replying. But now I can't unlock the screen by turning my watch to my face.
I guess there is no way I can still use that function while the double tap is enabled ?
Best Answer09-10-2019 11:38
09-10-2019 11:38
Hi, you can do this only during your swimming and after that set it to automatic again. It's not that much work.
Best Answer09-10-2019 11:54
09-10-2019 11:54
Ooh wow, ofcourse I can do that. Didn't even think about that hahaha.
Thanks !
Best Answer09-10-2019 12:08
09-10-2019 12:08
Thanks very much for marking it as an accepted solution, best regards kuzibri
Best Answer09-11-2019 12:03
09-11-2019 12:03
Hi @SunsetRunner and @Yentelke1998. Have you tested this solution, @Yentelke1998 . On my Versa, double tap will wake the screen, even in manual mode. Manual mode just means Quick View is disabled.
Best Answer09-11-2019 12:16
09-11-2019 12:16
Indeed, you are right. I just tested it.
Then my question still remains. Can I turn off the double tap option ?
Because that's the reason my watch turns on in contact with water
09-11-2019 12:18
09-11-2019 12:18
Hi Carol,
thanks for reply. On my Versa, that's why I mentioned the screen activation method, the double tap is a bit less sensitive when switched to manual versus automatic. Maybe that my just the drop during the swim session. Regards kuzibri
Best Answer09-11-2019 12:19 - edited 09-11-2019 12:21
I’m sorry to day there is not a way to turn off the double tap. You can suggest that as a new feature in the Feature Suggestion forum. This way, others can vote for your idea and Fitbit can gage interest.
Best Answer09-11-2019 12:24
09-11-2019 12:24
Alright, fair enough.
But what about all the other versa owners who likes to take a swim ? Because it seems like I am the only one who is complaining about this...
Best Answer09-11-2019 12:56
09-11-2019 12:56
This suggestion in the Feature suggestion Board has the status: "not supported currently", so it seems that it will not be available in the near future.
Best Answer09-11-2019 13:00 - edited 09-11-2019 14:50
Hi, I would advice you to try the manual setting of the screen during your swimming sessions, although it does not disable the double tap function, cause the screen is, at least on my Versa, is less sensitive for this feature than when set to automatic. This might prevent your Versa from switching on all the time. give it a try. If this works for you, your a happy man, if it does not work your problem will persist unfortunately. Please keep me posted on this issue. Regards kuzibri
