08-16-2018 08:19
08-16-2018 08:19
I loaded my credit cards onto my Versa wallet app and enabled the pin pass-code. I have since removed my cards from the wallet and would like to remove the pass-code prompt on my watch. Other posts state logging into my account on my phone app and locating "Device Lock", however I do not need this option.
Am I missing it completely or is this not an option within the Versa?
08-16-2018 10:14 - edited 08-16-2018 10:17
That looks like the wrong section. Can you click on Versa somewhere after you've gone into the account/settings area? In the Windows app the Device Lock is in the same section as the Clocks, Apps, Media, Wallet etc.
If you find that section, scroll down toward the bottom and you should find Device Lock.
08-16-2018 09:13 - edited 08-16-2018 09:14
By tapping on "Device Lock" in the app, you should be able to disable it if it's still enabled. After you've disabled it, don't forget to sync.
https://help.fitbit.com/articles/en_US/Help_article/2250#how
08-16-2018 09:43
08-16-2018 09:43
I don’t need see the button for that.
