11-27-2018 08:16
11-27-2018 08:16
I received a text notification, which I have now read on both my phone AND my Versa, but my Versa is still showing it as a notification, I have selected the 'clear' and 'clear all' on the watch, but the notification remains there ![]()
Can anyone help please?
11-27-2018 21:24
11-27-2018 21:24
@j3creations Try rebooting your Versa several times by pressing and holding the left and bottom right buttons until fitbit logo flashes.
11-27-2018 21:24
11-27-2018 21:24
11-28-2018 00:28
11-28-2018 00:28
11-28-2018 13:23
11-28-2018 13:23
@j3creations let me know if it resolved the issue.
11-28-2018 13:55
11-28-2018 13:55
11-28-2018 13:58
11-28-2018 13:58
@j3creations Usually majority of little things like that can be resolved by rebooting Versa's little brain. 😋 Enjoy your tracker! 😊
01-08-2019 16:07
01-08-2019 16:07
I am having the same issue with my Ionic - no matter how hard I try to clear a notification it never clears. At first it was just one notification from a group text, now I have another group text notification that won't clear. I'm guessing it doesn't like group messaging ????
Does your solution work with Ionic? AND if I reset do I lose all my progress for the day???
Thank you
Best Answer01-09-2019 02:21
01-09-2019 02:21
@ShanMcIn you will not lose any data. It should work as it's the same OS and the same Fitbit app.
02-17-2019 19:56
02-17-2019 19:56
It worked perfectly. Ty
Best Answer04-22-2019 09:18
04-22-2019 09:18
Fixed! Thanks
Best Answer09-05-2019 13:56
09-05-2019 13:56
I reboot all the time because notifications keep getting stuck on my Versa. Anyone knows why this keeps happening? The frequency is increasing.
