10-30-2018
02:25
07:43
MarcoGFitbit
10-30-2018
02:25
07:43
MarcoGFitbit
Versa, Galaxy S9+, I've got music controls to work once (no idea how) and never since. I'm connected to my phone, the Versa just says to start playing music on the phone - well, when I do, nothing happens. Every guide I find on this site tells me how to get to the point I'm at basically (pair with classic, change source, etc) and nothing about what to do when any of that doesn't work.
EDIT: turns out that it's definitely connected and everything as I can use the buttons on the Versa to change the volume - but I get no track info or controls whatsoever.
10-31-2018 07:56
10-31-2018 07:56
Hello @Spidergoat, thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. I would also like to thank you for letting us know the troubleshooting steps you've tried so far. At this moment, if you'd like to use Music Control with your phone, I would like to suggest you to try the following:
1. Start playing music on your phone.
2. Press down the left button on your Versa for 2 seconds.
3. On the next screen, swipe right to bring out music control
4. In here tap on the ellipsis (...) button on the bottom left corner.
5. Select phone as source:
6. Then, press the left button again, you will be able to see Music Control on the Versa's screen:
If the controls on the Versa screen are not working when you tap on them, please restart your Versa by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen and try again.
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
10-31-2018 08:14
10-31-2018 08:14
11-01-2018 08:18
11-01-2018 08:18
Hello @Spidergoat, I hope you're doing well, thanks for taking the time to reply.
I appreciate you have come back and let me know you've already tried the instructions provided. I’ve reached the limits of what I can do for you here on the public community forums, so I've contacted our Support team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions.
In case you need anything else, please feel free to reply as well. Happy stepping.
07-07-2019 09:13
07-07-2019 09:13
I am having this same problem. I have followed all the instructions and still cannot get my versa to skip the songs. It says unable to connect to versa (classic)
