03-12-2019
15:39
07:32
MarcoGFitbit
03-12-2019
15:39
07:32
MarcoGFitbit
Hi,
I buy a new Fitbit Versa and paired with Xiaomi Redmi Note 6 Pro but I am unable to get notifications in Fitbit versa and setting show to restart your phone for enabling the notification and I did several to time restart but error remains same I had already updated the apps but still not worked what should i do please help me thanks
03-13-2019 07:34
03-13-2019 07:34
Hello @farrukh2019, have a warm welcome to the Fitbit Community, it's great to have you on board.
Please note that many Android phones, like the your device have all the hardware requirements to be a supported device but are currently not on our list of supported devices. This means that we have not tested it for compatibility and added it to the list yet. For the time being, we don't have an specific date or time-frame of when is going they will be listed as compatible.
However, Notifications skip or stop occasionally for several reasons that don't suggest a problem with your device or the Fitbit app, which is why I would like to ask you to check the following:
If you've reviewed the list above and can't get notifications to work, please try the following:
I hope this can be helpful, please give these steps a try and keep me posted in case you need anything else.
03-13-2019 16:09
03-13-2019 16:09
thanks for replay I had tried almost all above mention steps but unable to solve the issue still shows restart the phone to enable to the notification this error show all the time 2 time I had unpaired and proceeding the new setup but still not resolved ....... 😞
03-14-2019 10:04
03-14-2019 10:04
Hello @farrukh2019, I hope you're doing well, thanks for taking the time to reply.
I appreciate you have come back and let us know about this situation. Would it be possible for you to reply with a screenshot of the error you're getting where you're getting asked to restart the phone? This will be very helpful for us to check this further. Follow these steps to add a picture to your next reply.
Thanks for your patience and understanding, we'll be waiting for your next reply.
03-16-2019 09:51
03-16-2019 09:51
Hi,
I had attached the screenshot file please have a look and several times I had restarted and these notification errors still remain although I had tried your given procedure tricker the solution but unable to resolve it the mobile phone is Xiaomi Note 6 Pro Screenshot is already attached please check
attachment thanks
03-18-2019 10:35
03-18-2019 10:35
Hello @farrukh2019, I hope you're doing well, thanks for taking the time to reply to us with some screenshots.
First of all, I would like to apologize for the delay in the response. I appreciate you have come back to us with the screenshots requested. At this moment, I will forward them to our team so they can take a better look at this situation, but please note that as your phone is still not listed as a supported device, that might be the cause you're not receiving Notifications.
Please keep an eye on the list, as we constantly update it to include more phone models. If there's anything else we can do in the meantime, please let us know.
Happy stepping!
04-14-2019 19:48
04-14-2019 19:48
Hey, I'm having the same issues and I was wondering when it will be fixed...
05-06-2019 13:01
05-06-2019 13:01
Hello
Any news on this issue?
I'm having the same problem with my Redmi Note 6 Pro and Versa Lite.
05-07-2019 08:16
05-07-2019 08:16
Hello @Jophur and @Amandamagalhaes thanks for joining the Fitbit Community.
First of all, I would like to apologize for the delay in the response. I appreciate you have joined the conversation and let us know you're also being affected by this situation. At this moment, in case you haven't done it yet, please go to your phone Settings > Manage apps > Fitbit and make sure "Autostart" is on.
Then, scroll down and tap on Settings > Manage apps > Fitbit > Notifications and make sure "Show Notifications" and "App Icon Badge" are on. If you're still not getting notifications, restart your phone.
Thanks for your patience and understanding, Give this a try and let us know the outcome!
09-01-2019 01:21
09-01-2019 01:21
I have experienced the same problems with a ticwatch e2 and redmi note 7.
Did you resolve this?
This is a known problem but still no solution???
09-10-2019 07:45
09-10-2019 07:45
That worked. Thank you so much
10-30-2019 08:02
10-30-2019 08:02
Hi Fitbit. I havr the same concern i am unable to get notifications on my Xiaomi Redmi Note7.
12-18-2019 04:14
12-18-2019 04:14
SOLVED! I have a Redmi Note 8 Pro and have scoured the internet for the past two hours trying to find a solution that worked. I tried literally every other suggestion on all the help pages.
Turning on the "Autostart" setting for the Fitbit app in "manage app settings" immediately fixed the problem!
I previously had a Xiaomi Mi Mix and had a similar issue where it wouldn't get notifications, but it ended up being the battery saver stopping it from working. The Xiaomi phones just seem to have specific settings which stop them from allowing syncing and notifications.
Thanks for the help everyone!
12-25-2019 15:13
12-25-2019 15:13
Awesome man. I got a Redmi Npte 8 pro this x-mas. Can you post some screen shot of your settings? my messaging is broken It does not display any notification.
12-26-2019 00:16
12-26-2019 00:16
You just go to Settings > Apps > Permissions > Autostart and allow it for Fitbit, as seen in my screenshot:
04-27-2020 02:06
04-27-2020 02:06
Hi,
You wrote that you solved the connectivity problem.
Do you have still have any problem - connectivity issues with fitbit and Xiaomi Red Mi Note 8 pro ?
A friend of mine is planning to buy a Note 8 pro but has concerns about fitbit connectivity
04-27-2020 05:59
04-27-2020 05:59
Hi there, after I changed the settings, I didn't have any more issues! 🙂
07-05-2020 04:37
07-05-2020 04:37
I am using redmi note 9pro but my Fitbit charge 3 is not showing notification
In the app it's showing notification is not showing need to restart the phone but I have don't many time still the same message plz help me out
08-03-2020 04:18
08-03-2020 04:18
Thanks!!!!
10-20-2020 14:10
10-20-2020 14:10
I recently got the Fitbit versa 3 for my birthday and still have the issue even though I turned this setting on my note 8 pro... Did you experience any other problems?
