Unable to get drinking reminder or set up reminder
ANSWERED
Need guidance on how to setup reminder for drinking water
1 BEST ANSWER
Accepted Solutions
@Divesh Unfortunately, Fitbit itself does not have this feature. Perhaps you could add this suggestion to the Features Suggestion Forum.
Nevertheless, you can always install Water Drink Reminder app on your phone and then go to the fitbit mobile app, tap on Versa icon, scroll down to notifications and enable the water reminder app there.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
11 REPLIES 11
Try SimpleClock, it has an on watch option to remind you to drink, along with a count of your daily intake.
https://gallery.fitbit.com/details/b3d7fabf-4cb1-4e58-9253-19697ce22800
Thanks for the response.
After long time my issue is resolved.
Drinking reminders are useful.
Thanks for earlier suggestion and I used it.
But i see that SimoleClock screen has always 0 for the water level/reminder.
I added 400 ml plus but it did not change at all.
Also it does not give any reminder.
I have activated that in settings after clock was selected.
40 m and 50 m reminders are working well
You have to clear the SImpleClock reminder, by clicking on it.
Each time you clear the reminder it will add 1 and start a countdown for a new reminder.
The icon on the clock face is blue when you need to drink.
When you click on it it goes clear [IE. glass now empty] and will be blue [full again] in an hour from when you clear it.
That way you can set your own rhythm when you start and when you drink.
Although the reminder is blue you might only be able to drink later, in the meantime it stays blue until you drink and clear it.
Would you please rate the app as a test.
Thanks
Thanks Guy,
After several tap on the glass i could see 1 and empty glass 🙂
where would i rate it as test?
Glad it's working.
Touch screen requires good ambient light to work first time, and of course an accurate finger!
In the phone app where you select a clock face there is a "rate this item" press on the 5th star if you like it.
You can always change later by going to "see all details"
There is no water reminder app for the band... reminder is limited to phone only.
Hi @Neha_breeze - depending on your watch there are different clock faces in the Gallery (see above) which do drink reminders.
As this is an old post, try SimpleClockPro for starters.
