08-29-2018
07:03
08:13
MarcoGFitbit
08-29-2018
07:03
08:13
MarcoGFitbit
Hi my versa does not recieve any notifications any more. It use to recieve call, tests and email then my samsung 7 had an update and since then nothing comes through.
Any idea what i can try??
08-30-2018 08:18
08-30-2018 08:18
Hi there @Tasious89-, have a warm welcome to the Fitbit Community, it's great to have you on board.
Thanks for taking the time to report this to us. Have you restarted your Versa recently by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen? Have you checked if your Versa is not currently on the Do Not Disturb Mode? You can check this by pressing the button on the left for 2 seconds. In the next screen swipe left and check that Notifications are ON. If everything seems right with your tracker I would like to suggest you to reset Notifications from the Fitbit app following these steps:
- Go to the Bluetooth settings on your phone and tap on tracker. Then tap on Forget this Device.
- Force-close the Fitbit app.
- Open the app again and tap on Account > Versa > Notifications.
- Then, the app will begin setting up your tracker with the Bluetooth on your phone.
- Once you get back to the tracker options, tap on Notifications an enable the ones you'd like to receive.
Additionally, if the connection between your phone and Fitbit device is unstable, Bluetooth signals might be susceptible to disconnecting or dropping occasionally, which is why I would like to ask you to please check the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
08-30-2018 08:18
08-30-2018 08:18
08-30-2018 09:53
08-30-2018 09:53
Thank you so much Marco the first thing you suggested has worked.
Many thanks
