11-21-2018 00:20 - last edited on 11-22-2018 07:30 by MarcoGFitbit
In my Fitbit Versa, notification service is not running..how do i set it up..I have tried many times to enable it..but it's not happening..please anyone help me ??
11-21-2018 12:11
11-21-2018 12:11
@rachitV123 Does this error message persists even after rebooting the phone? Does it ever disappear?
A few ideas:
1. Make sure Fitbit mobile app is not being optimized by Android. Go to your phone's battery settings and disable battery optimization for Fitbit app.
2. Lock Fitbit mobile app in the background, so it doesn't get killed by Android. Please take a look at this link.
3. In the Fitbit mobile app, tap on Versa icon in the top right corner, and scroll down to Keep Alive Widget. Enable it. Also, enable always connected.
11-21-2018 01:10
11-21-2018 01:10
@rachitV123 you mean in the Fitbit mobile app on your phone? Is that an error message yourey getting? If yes, just reboot your phone.
11-21-2018 01:13
11-21-2018 01:13
11-21-2018 01:15
11-21-2018 01:15
@rachitV123 so you're not getting any error messages on your phone like "notification service not running..."? What phone model and OS do you use?
11-21-2018 01:19
11-21-2018 01:19
11-21-2018 01:23
11-21-2018 01:23
@rachitV123 you will need to attach the pic in the post using a web browser. Also, please share phone model and OS (Android, iOS, etc)
11-21-2018 01:27
11-21-2018 01:27
I'm using Android phone with miui 10
11-21-2018 12:11
11-21-2018 12:11
A few ideas:
11-21-2018 19:39
11-21-2018 19:39
Thank you so much😊
11-22-2018 09:25
11-22-2018 09:25
@rachitV123 you're welcome! Enjoy your versa. 😊
11-22-2018 09:28
11-22-2018 09:28
11-27-2018 11:11
11-27-2018 11:11
I am using my fitbit versa in redmi note 4 but not getting any notifications instead getting the same message again again to restart my phone ...any helps ?
11-27-2018 14:04
11-27-2018 14:04
Hi there I can’t receive notifications on my iPhone 7ios12.1. Fitbit support can’t help me even though I have been contacting them weekly for 2 months. I have tried everything Marrrmaduke has suggested over and over again but still doesn’t work and Fitbit won’t exchange for a new one
11-27-2018 17:17
11-27-2018 17:17
I have tried the steps you suggest but the problem still persists. The error message "Notification service not running..." is always there. My phone is a redmi note 5 pro with MIUI 10.0.4.0
11-27-2018 20:35 - edited 11-27-2018 20:52
@waqar_ws try uninstalling and re-installing fitbit mobile app with a reboot of your phone in-between. Also, make sure that Fitbit mobile app can run in the background (Go to your phone's Settings>Apps>Fitbit>Battery and make sure Background Activity is toggled ON). If all fails, I recommend all the steps mentioned in my earlier post plus downgrading Fitbit mobile app to version 2.74. You can find it on the internet.
11-27-2018 21:22
11-27-2018 21:22
@Abhay_Dubey I merged your post with this thread. Please check it out for answers to your question.
01-10-2019 14:15
01-10-2019 14:15
Since the last MIUI 10.2.1 update v2.84 of the Fitbit app seems to work properly with my Versa. I'm getting consistent notifications and no notification server errors. 🤞
I've got the app locked, granted all permissions and set battery saver to 'no restrictions'
I've got a Redmi Note 5.
01-10-2019 14:39
01-10-2019 14:39
@Mamamegs I'm glad! 👍🏻😊
01-12-2019 12:08
01-12-2019 12:08
This solution works for my Versa and Pocophone.
01-12-2019 22:13
01-12-2019 22:13
@AndreScholten Awesome! 😄
