12-27-2018 22:49
12-27-2018 22:49
I have a Fitbit versa. I hadn't used it for a while. I started using it again sometime in the start of December. It workse fine for a while but now it is not syncing with the app. It connects via Bluetooth and starts syncing, but then suddenly stops. I changed the password of my wifi( the one which Versa connects to). But when I take the 'configure wifi' option the list of wifi connections does not load. Because of this I haven't been able to update it either. What could be the problem?
12-27-2018 23:12
12-27-2018 23:12
@Karthik_G what's your phone model and OS? Let's try restoring the connection first:
After syncing, go to Wifi in the Fitbit mobile app and re-add your network. Update Versa if the update is available in your Fitbit mobile app. Make sure you're running the latest version of the app.
Just a note: I usually update over wifi, then promptly remove the network as I find it's causing sync issues with my phone.
12-27-2018 23:12
12-27-2018 23:12
