05-27-2020 05:36
05-27-2020 05:36
Hi all. I have a Versa which has blocked. I get the message to ‘unlock from phone’. I have no Versa assigned to my account on either the desktop app, nor the mobile one.
I have tried a hard reset, re-installing/syncing the Versa, but all variables result in ‘unlock from phone’ messages.
There is no reset PIN area on my dashboards.. presumably as there is not a recognised Versa attached to my account!
Also couldn’t find a link to contact Fitbit support to ask them.. all a bit bizarre, and I’m now getting a tad frustrated with it all.
Any ideas or recommendations gratefully received!
Thanks & Regards
05-27-2020 10:34
05-27-2020 10:34
Sounds like you are saying that the Versa has been removed from your Fitbit account @Youngson.
Your saying that when logging into Fitbit.com your account doesnt show a Versa connected
Ok you may want to contact Fitbit and have them walk you through the steps or just try.
Fitbit OS hardware reset.
On the watch, hold all three buttons for about twelve seconds. This will trigger the 2-button hardware restart after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, whilst continuing to hold the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
05-27-2020 13:53
05-27-2020 13:53
