11-21-2018
07:53
07:29
MarcoGFitbit
11-21-2018
07:53
07:29
MarcoGFitbit
Hello,
I just received the new versa on Monday, I have had two Charges and now for the upgrade.
I tried to sync it with my iPhone got through all setup then it had a download update after wifi and Bluetooth connection. It has not worked, never downloads. Well I know it’s time for a new cell phone so I got one yesterday. Still the exact same problem. Is there something wrong with the watch?
Thanks!
11-21-2018 12:47
11-21-2018 12:47
@LoraGurl what error message are you getting? Which iPhone are you setting up your Versa with and what's the iOS version?
11-21-2018 17:31
11-21-2018 17:31
Thanks!
No error just always downloading but never downloads. Stays around 5 percent. I have tried a few times over day, through the day etc.
I have 12.0.1 my other phone I tried it on was 11.3.
i can’t do the newest version yet as my phone isn’t fully set up. Is that the problem?
11-21-2018 17:54
11-21-2018 17:54
@LoraGurl no, it shouldn't be an issue. Are you downloading via bluetooth? In other words, did you manage to set up wifi on your Fitbit?
11-21-2018 18:07
11-21-2018 18:07
I did manage to set up wifi. But I am just doing the update through the app. Is that correct?
11-21-2018 19:36
11-21-2018 19:36
@LoraGurl Yes. It's correct. Can you take a screenshot of the Fitbit mobile app window and post it here. I think you will have to restart the whole process. Try rebooting your versa and phone. Make sure both phone and versa are really close to your wifi source.
11-21-2018 20:09
11-21-2018 20:09
I am in bed so I can post one tomorrow sorry. But I have tried on two phones and rebooted both phone and watch and have tried to load several times. I am close to the wifi. I can try closer but full single on my phone and computer. I will try redoing it in the morning and screen shot it after. Thanks
11-22-2018 07:39
11-22-2018 07:39
Hello @LoraGurl, thanks for joining the Fitbit Community, it's great to have you on board. It's nice to see you too @Marrrmaduke, thanks for all your help.
@LoraGurl, I appreciate your participation in the Forums and for sharing your experience with us. Before you begin the firmware update, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
11-22-2018 09:39
11-22-2018 09:39
@LoraGurl thank you. Please post a screenshot of the Fitbit app as well as a picture of your Versa's display. I would like to see where it's stuck.
11-22-2018 18:39
11-22-2018 18:39
These are the screens I keep getting:) thanks!
11-22-2018 19:20
11-22-2018 19:20
@LoraGurl Screenshot of the Fitbit mobile app too, please.
11-22-2018 19:32
11-22-2018 19:32
Sorry I thought both posted!
11-22-2018 19:52
11-22-2018 19:52
@LoraGurl I see. If I understand correctly you have versa linked with your account but not paired with your (new?) phone. You're trying to update but as versa is not paired it won't go through. That's what I would do:
1. Close the update in the app, so you can see main dashboard. You need to remove Fitbit versa from your Fitbit account.
2. Uninstall Fitbit mobile app
3. Reboot your phone
4. Reboot versa by pressing and holding the left and bottom right buttons until Fitbit logo flashes
5. Install Fitbit mobile app
6. Set up Versa as a new device (add device in the Fitbit mobile app)
7. Grant all requested permissions
8. Configure notifications, etc.
11-22-2018 19:54
11-22-2018 19:54
Thanks for your help!
11-22-2018 19:58
11-22-2018 19:58
Thanks! I will give it a go. This is my second phone trying it on. Same problem both phones. But I will let you know:) thanks
11-22-2018 20:04
11-22-2018 20:04
@LoraGurl it's because versa wants to be set up from scratch and your Fitbit mobile app thinks the tracker has already been set up and just wants to update it. Weird. If you cannot close the update screen, just uninstall and reinstall the app. Then delete versa from account and proceed as described.
