01-23-2020 19:57 - last edited on 01-24-2020 12:00 by LiliyaFitbit
I purchased a Used Fitbit Versa 2, that needs unlocked by phone. I have no way of getting a hold of seller for assistance. Is there anyway to hard reset the watch so that I can connect to my phone?
11-05-2020
03:52
06:13
JuanJoFitbit
11-05-2020
03:52
06:13
JuanJoFitbit
This is not working for me and keeps going back to unlock with your phone! this has never happened to me and I am usually able to resolve my issue but it just wont work.
this does not work omgg im so triggered.
Nope not for me
Moderator edit: merged reply
11-07-2020
11:24
06:15
JuanJoFitbit
11-07-2020
11:24
06:15
JuanJoFitbit
I’m having the same problem. My watched showed “unlock from phone” and I couldn’t figure it out. So I thought I’d disconnect it and reconnect it. Mistake. Now I can’t get it reconnected because it still shows the “unlock from phone” message and won’t show the numbers needed to connect the device again. I’m attempting to hard reset using the side button but it isn’t working. It’s not resetting completely. Whenever it turns back on, it immediately shows the “unlock with phone” message. I’ve deleted the app, updated the app, updated the watch, logged out, logged back in, reset from the side. I’m at a los. At this point I want to throw the thing in the trash and get an Apple Watch.
We’re you ever able to find a solution? I’m at the same level of frustration as you. I’m about throw this **ahem** in the trash and buy an Apple Watch
Is there a number to call? The app automatically sends you to twitter (which I’ve tried) and they don’t respond.
Moderator edit: merged replies
12-03-2020 09:55
12-03-2020 09:55
Hi! I have the same problem, and I can't get it to vibrate the second time and do the factory reset. Do you have any other ideas? Is there another option?
Thank you,
Nancy
01-11-2021
03:01
06:17
JuanJoFitbit
01-11-2021
03:01
06:17
JuanJoFitbit
Hi,
my son set a passcode for his Fitbit versa 2, to be unlocked via phone. He has now disconnected his device from his app and the watch is still locked.
I have tried the steps above, but it just brings up the Fitbit logo and then goes blank, brings Fitbit logo again and then brings up unlock with phone. Can you help please?
It’s now gone to a red x and looking at all the comments, not many have been successful in fixing this problem. Can anyone help?
thank you
Best Answer01-11-2021 06:33
01-11-2021 06:33
Best Answer01-14-2021 21:51
01-14-2021 21:51
I also experienced this and I understood what they meant, so delete the paired device from your Bluetooth, delete the app and install it again. The display will still say not synced but the 4 digit code will appear
02-11-2021 17:12
02-11-2021 17:12
For Versa 2, hold all 3 buttons until you see the fitbit logo appears then disappears. Once it disappears release the lower right button. Hold the left and upper right buttons UNTIL you feel the vibration then RELEASE the remaining buttons. Good luck. Check this https://thedroidguy.com/how-to-hard-reset-fitbit-versa-factory-reset-or-master-reset-1106801
Best Answer04-29-2021 12:52
04-29-2021 12:52
I'm pressing the back button but all its doing is pulling up the quick settings list. It never goes to the logo or a long vibration. is there another way to factory restore without a phone?
Best Answer06-09-2021 16:58
06-22-2021 03:45
06-22-2021 03:45
I have tried the above steps and doesn't see to work. Any further assistance would be greatly appreciated.
Best Answer07-13-2021 05:58
07-13-2021 05:58
Please can you explain it more briefly or with a video as I don't understand how to do it
10-17-2021 16:59
10-17-2021 16:59
I had this issue for over a month and just managed to fix it.
I went to the FITBIT APP and REMOVED my Fitbit Versa2 from the list of Synched Devices (didn’t logout);
In my phone’s (iPhone Max11) SETTINGS, I REMOVED Fitbit Versa2 (forget this device) from the connected devices’ list;
I then TURNED OFF Bluetooth connection in my phone‘s SETTINGS (toggled the button to the left);
I then TURNED OFF my phone.
RESTARTED the phone after a few minutes:
White the phone restarted, I pressed the BACK button briefly on Fitbit to bring back the Red Cross screen;
I then kept the BACK button pressed until the Fitbit screen went dark;
I then released the BACK button and waited for the Fitbit official logo to emerge on the device’s screen;
As soon as the Fitbit screen lit up with the official logo, I pressed the BACK button very briefly and released, forcing a hard-reset;
Once the Red Cross sign appeared, I went back to the phone’s SETTINGS and turned on the Bluetooth connection;
I then went to the FITBIT APP and clicked on the ADD DEVICE option.
The app instantly found Fitbit Versa2 and all I had to do was to follow the on screen instruction. It took the app under ten minutes to update itself and synchronise my Fitbit Versa2, which now runs like it should.
I hope it helps.
03-06-2022 20:43
03-06-2022 20:43
I have tried that but still didnt work
Best Answer04-20-2022 22:42
04-20-2022 22:42
Best Answer08-24-2022 08:13
08-24-2022 08:13
Hi!
I'm facing with the problem of RED CROSS with message DATA NOT CLEARED SYNC AND TRY AGAIN.
Pls help me to sort out this issue
I have been using Versa 2 about a month and started facing this problem.
Best Answer08-29-2022 07:13
08-29-2022 07:13
Took a couple tries but got there in the end. Thanks for the help. Thought I was gonna have to ditch it and get a new one
Best Answer10-27-2022 10:27
10-27-2022 10:27
If you see the "unlock with phone" icon and let's say you don't have the same phone used to set up the watch previously so you have no way to unlock with the "said" phone,
hold the button on the side for 8 seconds and then let go, then hold it down again. Just keep messing with holding that button down and releasing it every time you see the icon and then holding it down again. Confusing I know, just do it.
This will take you to a red cross failed to sync icon, then go into the app and set up a new device. The pin number will be displayed and you can set up your watch.
11-06-2022 15:09
11-06-2022 15:09
Hi,
I got the same message after I had followed the factory reset steps.
After that I went to my app and went to add a device. My app searched my fitbit successfully and a code was sent on my watch.
as soon as I entered the code in my mobile app, I could connect my watch to my app and the Red Cross with error message was gone and then my app installed data on my watch and I could connect and start using my watch.
Best Answer11-19-2022 14:38
11-19-2022 14:38
I purchased second hand fit bit sense and have same problem unlock with your phone. How to factory reset it?
Best Answer12-31-2022 01:43
12-31-2022 01:43
Hi sorry about this but its not work what button do i press
