08-04-2019 16:01
08-04-2019 16:01
It says I need to update the firmware, so I start the process. It takes about 20-30 minutes to get the progress bar all done, but then, it starts over. It's been running for a few hours, and it never stops. I stopped, rebooted, and restarted the process, but the same thing each time.
08-04-2019 17:52
08-04-2019 17:52
What phone are you using to update?
If android, after starting the update, switch to a different app to move the Fitbit app to the background.
If it still doesn't work try through both cellular and WiFi.
