Upgrade to Versa 3 or Sense?
Hello all,
I have a Versa 2 currently, and it's pretty banged up and malfunctions sometimes, so it's probably time for a new one. I can't decide if I want the Versa 3 or the Sense, though, since they both seem to have problems?
I'm mostly using my Fitbit to keep track of my RHR and my sleep because I'm always worried about both. Maybe working out in the future when I feel better.
I was hoping someone had experiences with both of these and could recommend which one is better?
I did buy a Samsung Watch 4, but I am returning it probably for one of these because I do not like the way it keeps track of HR and sleep compared to how the Fitbit does it.
1 REPLY 1
Hi @hakiyu  - as you have seen in the forums there are issues with the Sense and Versa 3, which are based on the same operating system and are very similar.
The vibration, floor count, heart rate, battery life, etc. should work well on a Versa 2. So probably the better option to just replace it, unless there is something specific you need, but then you might have to forego things you already have.
Following the Ionic recall a number of users have expressed disappointment with replacing it with a Sense and Versa 3.
