01-18-2020 07:44
01-18-2020 07:44
my versa keeps re-setting itself and freezing so I cant swipe my screen, is anyone else got this problem? I have tried re-setting it and nothing works!
Anyone got a clue???????
01-18-2020 09:02
01-18-2020 09:02
I believe we had the same issue. I tried factory reset and it didn’t help. I had to return it and I got a replacement.
01-18-2020 07:54
01-18-2020 07:54
I have tried everything I can think of, first thing this morning was the first time in days that I was able to swipe my screen. I was very close to hitting the factory reset button, but I read that I shouldn't do that, I have since tried to swipe but again it won't swipe for me!!
I am at a loss?
Best Answer01-18-2020 08:14
01-18-2020 08:14
Hi @Tarri , when your Versa is still under warranty, contact Customer Support. Regards kuzibri
01-18-2020 09:02
01-18-2020 09:02
01-18-2020 09:42
01-18-2020 09:42
I called the fitbit support, and because mine is still under warranty they're replacing it (just the device, not straps or charger). Thank you for your advice!
01-18-2020 09:44
01-18-2020 09:44
Best Answer01-18-2020 09:52
01-18-2020 09:52
What is the number to call, I don't find it, it's like we can only join the support by mail...my versa 2 watch is not working well, the touch screen is not responding and I'm getting frustrated!
Best Answer01-18-2020 09:55
01-18-2020 09:55
The number I called was 18776234997
Best Answer01-18-2020 09:59
01-18-2020 09:59
Hi @Mmlachance , you can also chat with them. On the Support Page press "Fitbit Troubleshooting", scroll down the page and at the bottom on the right side you will see: "Let's talk" and press "Get Support". regards kuzibri
Best Answer01-18-2020 11:04
01-18-2020 11:04
