10-18-2021
20:08
05:49
10-18-2021
20:08
05:49
My Versa2 has stopped syncing with my IPhone 12 for no apparent reason. Have tried everything I can think of but can’t get them RE-synced. Suggestions?
10-18-2021 22:27
10-18-2021 22:27
I’m having the same issue! Hasn’t worked since last Wednesday.
10-19-2021 05:52 - edited 10-09-2024 08:19
Hi there, @krob61 @SunsetRunner. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Versa 2 automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If the issue persists, see Why won't my Fitbit device sync?
Hope that helps.
10-19-2021 06:55
10-19-2021 06:55
10-19-2021 07:12
10-19-2021 07:12
I am returning this devise! I have wasted so much time with the syncing and the re-syncing wish I would have read more reviews! Will switch to apple. Don’t buy this devise!!!!
10-19-2021 22:36
10-19-2021 22:36
Me too. Tried restarting. Deleted app. Re installed. Turned off/on Bluetooth. It will not connect. It can’t pair now. And for No Reason. Just random!! Grrr
10-20-2021 03:47
10-20-2021 03:47
Hi I’m having the same problem, my Fitbit app won’t refresh! Any ideas ? I would be grateful. Than you
