04-05-2019 16:36
04-05-2019 16:36
I've had my Fitbit Versa less than a year and the last week or so it's randomly turning off even when the battery is completely charged. Also when it is charged at 100% the battery starts to drain immediately while just sitting.
04-05-2019 17:05
04-05-2019 17:05
Hi, try restarting your Versa 4-6 times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons, If that does not solve your problem, contact Customer Support and ask for a battery test.
04-06-2019 08:57
04-06-2019 08:57
@Creola117 Welcome to our Fitbit Community! It's not normal that your Versa's battery drains immediately.
In addition to the restart process that shared my friend @SunsetRunner, I'd like you to check out and follow the tips that are listed in this help article in order to improve the battery life of your Versa.
Keep @SunsetRunner and me posted on the outcome! 😀
07-16-2022 07:18
07-16-2022 07:18
This literally just happened to my replacement fitbit 2. Apparently at 10:40pm last night it had a battery of 67% and woke around 10am to find that the battery had completely drained; and is now on the charger.
The restart process was completely non-responsive. My Fitbit has the most current firmware. Any insights would be welcomed.
