Vera not holding charge for a day - will hold for 4 hours
Hello, please help. Over the last 3 days I have had to charge my versa each morning as it has died at either 0400-4030. Before this I would get at least 4 days out of a charge,
the change is holding less and less each day. Yesterday I charge at 0700 and then at 1400 as it had died on my arm.
I have done the below to help the battery:
- removed all alarms
- cleaned the charger point
- cleaned the adapter top
- reset versa x 4 times
- turned off the Vera and phone x4 to rest both
- turned Bluetooth off
- turned all locations
- not use fitness.
I really want to get this sorted please help.
Thanks
3 REPLIES 3
I'm having the same issue.
Have you been able to fit it kanagy08?
it’s really annoying to be charging it not 3 times a day and loosing steps and goals while it’s charging.
Can anyone help please? Thanks
