11-11-2019
06:21
04:57
LanuzaFitbit
11-11-2019
06:21
04:57
LanuzaFitbit
I read the posts regarding this issue, and mine is definitely an alarm and not related to my goals. The screen says "Look Alive" and goes off again in 9 minutes if not dismissed. I reset the Versa 2 to factory settings and that didn't help. I have reset it back to factory settings, removed and reinstalled it in the app. That worked for one week and it went off this morning again. I have no alarms set what so ever at this time.
Moderator edit: Labels
01-17-2020 03:36
01-17-2020 03:36
I’m so glad I found this post because I have been having the same problems. No alarms whatsoever saved and my Fitbit alarm goes off at 6:20am every morning. I have had to stop wearing it to bed but can hear it vibrating on the bedside table. I just figured out how to fix it! I held the left button (for alexa) and when I did a tiny icon appeared in the upper right corner that looks like a clock face. When I clicked on that it took me to a screen that said alexa had a 6:20am alarm set every day! I must have asked her for an alarm at some point and forgot or maybe it was a glitch, but I turned it off! I also held the button and said “cancel all alarms” just to make sure, and she said “canceling all alarms”. Hopefully this helps you too, I have been so frustrated.
11-11-2019 08:18
11-11-2019 08:18
Hello and welcome to the Fitbit Community @giff57
This alarm is quite odd an I’ve never heard of it. I did look around and found this thread that may help you resolve this issue: https://community.fitbit.com/t5/Ionic/Look-Alive-what-is-this-notification-on-Ionic-and-how-does-one...
😃 Please let me know if this does indeed resolve your issue. If it does indeed answer your question could you please tap “choose as best answer” box just under my post? Doing this really helps other individuals who come to this Fitbit Community looking for answers to questions similar to your own. I’d really appreciate it!
Best Answer11-12-2019 06:42
11-12-2019 06:42
Hello again @giff57
I just wanted to check in with you to see if my post helped you solve your issue? If that did resolve your issue could you please tap “choose as best answer” under my post with my suggestion? It helps others find answers to questions like yours. I’d really appreciate it! 😃
Best Answer11-12-2019 06:45
11-12-2019 06:45
Best Answer11-12-2019 07:13
11-12-2019 07:13
Hello again @giff57
I believe I may have found the answer here:
Tap alarm icon
This will bring up a list of any alarms that are set
It also might have a new alarm.
Tap on the alarm you want to alter change state or remove .
Tap the time to change
Tap on or off to turn on or off
Tap the day of the week you want the alarm to sound
Or scroll up and tap remove.
If that doesn’t resolve your issue look here:https://community.fitbit.com/t5/Versa-Smartwatches/How-to-turn-off-Look-Alive-notifications/td-p/386...
😉 Please come back and let me know if this helps
11-12-2019 10:30
11-12-2019 10:30
11-12-2019 11:29
11-12-2019 11:29
Hello again @giff57
I truly want to help you. I know it has to be incredibly irritating to get an alarm every night in the middle of the night. I’m going to try and get someone to assist me in helping you. Hopefully I can find some who may know the answer.
😉 I’ll keep you posted
Best Answer11-12-2019 11:44
11-12-2019 11:44
Best Answer11-12-2019 13:19
11-12-2019 13:19
Hello again @giff57
Im still hunting down an answer for you but in the meantime can you check your Fitbit App to make sure the Alarm is set on the Fitbit App and not on your Fitbit tracker. Here’s how:
Also please perform a restart on your a Versa 2 as well. You will not lose your data doing this. Look here to find the proper steps to restart: https://help.fitbit.com/articles/en_US/Help_article/1186
Best Answer11-12-2019 14:15
11-12-2019 14:15
11-12-2019 15:46
11-12-2019 15:46
11-12-2019 16:01
11-12-2019 16:01
Best Answer11-12-2019 16:25
11-12-2019 16:25
Thank you for your insight and help @SunsetRunner! 😃
Best Answer11-13-2019 09:28
11-13-2019 09:28
So, this didn't solve the problem. The alarm went off this morning and I had no calendar event today. I am still looking for a solution. I purchase the Versa 2 for its sleep analysis, and the device is pretty useless if I cant get this fixed.
Best Answer11-13-2019 10:11
11-13-2019 10:11
Thanks for letting us know, @giff57 - The other thing I can think of is this - do you have any alarms set on Alexa, which works with your Versa2?
Best Answer11-13-2019 10:25
11-13-2019 10:25
Best Answer11-13-2019 11:12
11-13-2019 11:12
Hello again @giff57
Can you please check your dashboard here online to ensure that there may be an alarm sitting in there that for what ever reason might not be showing on your Versa 2 or on your Fitbit App.
heres how:
Best Answer11-13-2019 11:34
11-13-2019 11:34
11-13-2019 13:11
11-13-2019 13:11
Hello again @giff57
Alright I’ll take one last stab at this because otherwise I have no idea as to why this alarm at midnight comes in. It occurred to me just now that I got a new phone recently and one of the apps preinstalled on my new phone was a “reminder App”. As I was setting up my phone this particular app keep trying to link up with other apps I was setting up. Do you have any type of “reminder app” that you may have inadvertently allowed access too and it still has the alarm in question still attached to it? It’s a far reach but I’m running out of ideas.
Best Answer11-13-2019 13:32
11-13-2019 13:32
