11-11-2019
		06:21
		04:57
			LanuzaFitbit
		11-11-2019
		06:21
		04:57
			LanuzaFitbit
I read the posts regarding this issue, and mine is definitely an alarm and not related to my goals. The screen says "Look Alive" and goes off again in 9 minutes if not dismissed. I reset the Versa 2 to factory settings and that didn't help. I have reset it back to factory settings, removed and reinstalled it in the app. That worked for one week and it went off this morning again. I have no alarms set what so ever at this time.
Moderator edit: Labels
11-13-2019 15:10
11-13-2019 15:10
Thank you for your patience with us, @giff57 . You have us stymied! Please come back to let us know how the issue was resolved.
11-19-2019 07:05
11-19-2019 07:05
It sounds like you've got Reminders to Move turned on. Try turning that off. Also, have you set Sleep Mode on? If that's on, you can set a time for notifications to not come through. Good luck.
 Best Answer11-19-2019 07:33
11-19-2019 07:33
 Best Answer11-27-2019 22:47
11-27-2019 22:47
I’m not alone now! Mine goes off at 10:30 every night. I’ve tried everything as well that was mentioned with no luck also.
 Best Answer11-28-2019 07:05
11-28-2019 07:05
 Best Answer12-18-2019 11:16
12-18-2019 11:16
My Versa2 just started the same behavior with the alarm going off at midnight. Like you, I've shut off all alarms.
Did you get yours to stop? What did you do?
 Best Answer12-18-2019 11:35
12-18-2019 11:35
 Best Answer12-25-2019 15:06
12-25-2019 15:06
Yes, I had a Blaze, but I deleted it from the app around September when I got the Versa 2. I didn't experience the phantom 12am alarm until about two weeks ago.
Like you, I've factory reset the Versa 2, deleted the app, reinstalled and synced the device. No phantom alarms for about a week, and the 12am alarm started again.
So infuriating when I'm having issues falling asleep, and especially getting back to sleep once I wake up during the night. I like tracking my sleep, but due to this I'm not even wearing it to bed any longer.
 Best Answer12-26-2019 05:04
12-26-2019 05:04
 Best Answer01-15-2020 13:11
01-15-2020 13:11
I have the same issue except mine goes off at 5 AM
 Best Answer01-17-2020 03:36
01-17-2020 03:36
I’m so glad I found this post because I have been having the same problems. No alarms whatsoever saved and my Fitbit alarm goes off at 6:20am every morning. I have had to stop wearing it to bed but can hear it vibrating on the bedside table. I just figured out how to fix it! I held the left button (for alexa) and when I did a tiny icon appeared in the upper right corner that looks like a clock face. When I clicked on that it took me to a screen that said alexa had a 6:20am alarm set every day! I must have asked her for an alarm at some point and forgot or maybe it was a glitch, but I turned it off! I also held the button and said “cancel all alarms” just to make sure, and she said “canceling all alarms”. Hopefully this helps you too, I have been so frustrated.
01-17-2020 04:39
01-17-2020 04:39
Good job of trouble shooting, @Buckymarie ! Thanks for sharing with us so that others can try your solution.
01-17-2020 16:46
01-17-2020 16:46
Checking Alexa did not work for me, my alarm goes off at 3:31am every day, called Fitbit, they had me change some settings, it worked for a few days but it's back.....any other ideas?
 Best Answer01-17-2020 17:13
01-17-2020 17:13
02-11-2020 01:33
02-11-2020 01:33
Genius!! I have been struggling with a 5.30 am alarm for months and I found it in Alexa! You have saved my sanity..........thank you 🙂
03-11-2020 04:18
03-11-2020 04:18
Thank you so much. This solved the problem. I
05-02-2020 08:42
05-02-2020 08:42
THANK YOU SO MUCH! I also have been struggling with an alarm that has been going off at 430am on my Versa2. I did a reset of the device but alarm continued going off and was driving me crazy! I had no idea I had set an alarm with Alexa. 🙏 so much! I can wear my Fitbit to bed again! ALOHA!
05-13-2020 15:18
05-13-2020 15:18
I had an alarm that went off every Wednesday @ 5am. I deleted all of my alarms. Sure enough I saw your reply & went to Alexa...lo and behold, I had an alarm set. Just deleted. THANK YOU!
 Best Answer07-04-2020 08:20
07-04-2020 08:20
New Versa 2 user - transferred over from an Inspire.
I set up my alarms, however they are not going off when I have them scheduled and some are going off when i DID NOT schedule them. There are no alarms set via Alexa (checked). My alarms are set up below:
8a
1030a
1230p
3p
530p
730p
An alarm went off at 730a (and NO - i did NOT accidentally put am instead of pm), and my 8a alarm did NOT go off at all.
There is NO WAY to set silent alarms up in the app - this is a total miss on fitbits part!! So whoever keeps recommending you go there to check alarms - is wasting our time!
 Best Answer09-14-2020 07:54
09-14-2020 07:54
Thank you so much Buckymarie!!! You solved my alarm problem.
