10-07-2019 07:50
10-07-2019 07:50
So I've compared the HR monitor in the Versa 2 to the H10,
and there's such a big difference between them (10-20 BPM) during workouts that I feel that the Versa 2 is not even worth using in the gym (I've been trying for a week during my Push/Pull/Legs routine and it just doesn't work well enough). Somehow it seems to work well when running, but during lifting it just doesn't do well. I'll probably make a post about this later with detailed info.
Does anyone know if there's any way to connect the H10 directly to the Versa 2 without having to go through 3rd party apps like Strava to import kcals? 3rd party apps won't import the BPM as far as I know, which I really want in the Fitbit app, as I'm trying to use their ecosystem with Aria 2 to create a detailed and accurate view of kcals in/out etc. I would like to measure the BPM straight from the H10 to the watch, and I know that Polar has open API's so that shouldn't be to much trouble for Fitbit to fix.
Does anyone know if that's possible right now or will be soon?
10-07-2019 12:37
10-07-2019 12:37
I wouldn't bet on it. In my opinion, it will never happen.
10-07-2019 08:03
10-07-2019 08:03
No. There is no Fitbit device that can connect to external sensors of any kind.
10-07-2019 10:39
10-07-2019 10:39
Do you know if it's in the making? Doesn't seem to be much of a "smart" watch if it can't connect to anything else.
10-07-2019 12:37
10-07-2019 12:37
