08-05-2021 23:19
08-05-2021 23:19
Hello Folks
Over the past week the heart rate monitor on my Versa 2 has stopped working, no green light etc. I’ve tried restarting it several times. At first it would come on for a short period of time then go off again, now it will not come on at all. I bought this Versa less than a year ago. Anyone else having similar problems?, I’ve a feeling the latest update has effected it, but cannot be sure.
08-06-2021 00:59
08-06-2021 00:59
Hi yes having same problem. Not even 8 months old . Thinking of moving to another tracking device . This is my third Fitbit in as many years
08-08-2021 06:19
08-08-2021 06:19
Hi, I've got exactly the same issue. Stopped working last Thursday. Tried restarting, factory reset. It hadls once after a restart worked, but it lasted less than 2 mins.
Can we uninstall the latest update?
08-08-2021 09:23
08-08-2021 09:23
Updated mine to the latest firmware on August 6, and now having the same issue - Versa appears to be completely dead. Just talked to the Tech Support line, their thought is that it's a battery issue. Too coincidental for me, especially considering the similar results seen here after this latest firmware update.
08-08-2021 10:00
08-08-2021 10:00
08-08-2021 18:33
08-08-2021 18:33
I have had the same issue for the last 3 months. I have also tried to restart the device multiple times. There doesn't seem to be any help on the Fitbit web site. I don't think has anything to do with the latest update as I have had issues since May.
08-08-2021 20:08
08-08-2021 20:08
It can't be a battery thing...it HAS to have been from their latest update. Mine was working fine until I had that update. Grrr
08-09-2021 04:25
08-09-2021 04:25
Okay went through a factory reset with the tech support people this morning, requiring removing and reinstalling the Versa 2 . So far so good heart rate monitor up and running 👍😁
08-09-2021 14:34
08-09-2021 14:34
I also did the factory reset and reinstall as directed by tech support. It worked temporarily but again is not working correctly.
08-10-2021 06:12
08-10-2021 06:12
So after the reset working initially, the heart rate monitor has stopped again. Contacted support- as my Versa was within warranty they offered to replace it FOC or 50% off a newer model
