12-24-2022 06:50
12-24-2022 06:50
The watch bands metal clip broke the plastic insert on the watch band connection. I have a Versa watch now WITHOUT the ability to connect to a watchband.
I believe that a better design for the watch and band can benefit yout customers.
12-24-2022 07:50
12-24-2022 07:50
Hi @Beamamre if your 2 still works and you want to keep using it, go to Amazon. Look for a "fitbit versa 2 protective cover with band" and you'll find several that encompass the pebble portion of your Fitbit and still let you use it. Others on the forum have found this to be a workaround when they didn't want to buy a new device.
